Recording Mic+Computer audio!!
Hello, I’m trying to troubleshoot some issues I’m having with audacity. What I’m trying to do is record audio from both my mic (usb plug n play snowball), and audio from discord running in the background. For some reason I can only do one or the other but not both despite having success in the past. So it might be my settings that aren’t correct unless I need more/different hardware to pull this off. Anyone able to give me some directions? Much appreciated.
Re: Recording Mic+Computer audio!!
guys my issue got solved!!jakesons wrote: ↑Tue Sep 10, 2019 1:51 amHello, I’m trying to troubleshoot some issues I’m having with audacity. What I’m trying to do is record audio from both my mic (usb plug n play snowball), and audio from discord running in the background. For some reason I can only do one or the other but not both despite having success in the past. So it might be my settings that aren’t correct unless I need more/different hardware to pull this off. Anyone able to give me some directions? Much appreciated.
does anyone else had this same issue!!
