Possible improvement to Generate click track
Audio software developers forum.
Robert J. H.
Re: Possible improvement to Generate click track
Post by Robert J. H. » Tue Mar 31, 2015 10:51 pm
steve wrote:
rossmcm wrote:I'm not sure that you can ever make it "just as usable"
I think we make a pretty good attempt. There are not many things in Audacity that can't be done entirely from a keyboard, though yes there will always be some things that are less easy without a mouse or other pointing device.
The new scrubbing feature will probably be such a case.
As to the label context:
The keyboard workaround is probably:
- Select label track (alone)
- tab to the label (+ enter eventually)
- Choose the approbriate action from the edit menu, e.g. delete.
About the cursor:
It's essentially a synchronization question of the Audacity cursor and the system caret.
The latter should take the value of the former.
I can't say adhoc which WXWidget (accessibility) functions should be used to that end.
Robert
