The dialogue refers twice to "filtering". I doubt naive users know what that might mean but I assume it means remove, and the action choice is "Remove" (or "Isolate").steve wrote:There is no linguistic problem if we say we are "removing" noise and specifying "how much" we are removing. The effect of "removing" some of the noise is that we have "reduced" the amount of noise. To say that we have "removed" the noise is misleading because it implies that we have removed all of the noise, which as we all know causes unwanted side effects that can be worse than the problem that we started with.
It is clearly confusing for the name of the effect to be called something other than the action choice.
We can add Goldwave and CoolEdit to Steve's list of apps that have better noise reduction (better also in that they give better results at default settings).
My objection to the rename is not that we may seem to be saying we've watered it down but we are admitting it is not as good as it should be. If Audacity Noise Removal was better there would be much less demand for a name change (though "Noise Reduction" would have been a better choice to begin with).
I agree with Steve that any rename should be deferred until there is a substantial change in the effect (and probably therefore also GUI changes).
