Hi,
I'm having some issues calculating intensity from floating point samples obtained via an API in C# since I do not know if my implementation of FFT is correct.
Here is my main class and the FFT class I found on the internet:
test.cs (The main application class + method): http://pastebin.com/zKrpnsL6
FFT.cs (FFT class found on the net): http://pastebin.com/L3Na4Xuy
Edit: reader.Read(buffer, 0, 4096); this line reads 4096 floating point samples into the buffer. All help is appreciated guys!
Anyhow, I could really use some indication / help from you guys.
Thanks!
[C#] FFT Implementation
BurningCa007
dadabujontomasteel
- Probationer
Re: [C#] FFT Implementation
Well, don't know if this code will help you, if not, I don't know what else to offer.
Best Regards, David
Code: Select all
// Code to implement decently performing FFT for complex and real valued
// signals. See www.lomont.org for a derivation of the relevant algorithms
// from first principles. Copyright Chris Lomont 2010-2012.
// This code and any ports are free for all to use for any reason as long
// as this header is left in place.
// Version 1.1, Sept 2011
using System;
/* History:
* Sep 2011 - v1.1 - added parameters to support various sign conventions
* set via properties A and B.
* - Removed dependencies on LINQ and generic collections.
* - Added unit tests for the new properties.
* - Switched UnitTest to static.
* Jan 2010 - v1.0 - Initial release
namespace Lomont
/// <summary>
/// Represent a class that performs real or complex valued Fast Fourier
/// Transforms. Instantiate it and use the FFT or TableFFT methods to
/// compute complex to complex FFTs. Use FFTReal for real to complex
/// FFTs which are much faster than standard complex to complex FFTs.
/// Properties A and B allow selecting various FFT sign and scaling
/// conventions.
/// </summary>
public class LomontFFT
/// <summary>
/// Compute the forward or inverse Fourier Transform of data, with
/// data containing complex valued data as alternating real and
/// imaginary parts. The length must be a power of 2. The data is
/// modified in place.
/// </summary>
/// <param name="data">The complex data stored as alternating real
/// and imaginary parts</param>
/// <param name="forward">true for a forward transform, false for
/// inverse transform</param>
public void FFT(double[] data, bool forward)
var n = data.Length;
// checks n is a power of 2 in 2's complement format
if ((n & (n - 1)) != 0)
throw new ArgumentException(
"data length " + n + " in FFT is not a power of 2");
n /= 2; // n is the number of samples
Reverse(data, n); // bit index data reversal
// do transform: so single point transforms, then doubles, etc.
double sign = forward ? B : -B;
var mmax = 1;
while (n > mmax)
var istep = 2 * mmax;
var theta = sign * Math.PI / mmax;
double wr = 1, wi = 0;
var wpr = Math.Cos(theta);
var wpi = Math.Sin(theta);
for (var m = 0; m < istep; m += 2)
for (var k = m; k < 2 * n; k += 2 * istep)
var j = k + istep;
var tempr = wr * data[j] - wi * data[j + 1];
var tempi = wi * data[j] + wr * data[j + 1];
data[j] = data[k] - tempr;
data[j + 1] = data[k + 1] - tempi;
data[k] = data[k] + tempr;
data[k + 1] = data[k + 1] + tempi;
var t = wr; // trig recurrence
wr = wr * wpr - wi * wpi;
wi = wi * wpr + t * wpi;
mmax = istep;
// perform data scaling as needed
Scale(data,n, forward);
/// <summary>
/// Compute the forward or inverse Fourier Transform of data, with data
/// containing complex valued data as alternating real and imaginary
/// parts. The length must be a power of 2. This method caches values
/// and should be slightly faster on than the FFT method for repeated uses.
/// It is also slightly more accurate. Data is transformed in place.
/// </summary>
public void TableFFT(double[] data, bool forward)
// make table if needed
if ((cosTable == null) || (cosTable.Length != n))
Initialize(n);
var mmax = 1;
var tptr = 0;
while (n > mmax)
var wr = cosTable[tptr];
var wi = sign * sinTable[tptr++];
var j = k + istep;
mmax = istep;
Scale(data, n, forward);
/// <summary>
/// data containing real valued data only. The output is complex
/// valued after the first two entries, stored in alternating real
/// and imaginary parts. The first two returned entries are the real
/// parts of the first and last value from the conjugate symmetric
/// output, which are necessarily real. The length must be a power
/// of 2.
/// </summary>
public void RealFFT(double[] data, bool forward)
var n = data.Length; // # of real inputs, 1/2 the complex length
var sign = -1.0; // assume inverse FFT, this controls how algebra below works
if (forward)
{ // do packed FFT. This can be changed to FFT to save memory
TableFFT(data, true);
sign = 1.0;
// scaling - divide by scaling for N/2, then mult by scaling for N
if (A != 1)
var scale = Math.Pow(2.0, (A - 1) / 2.0);
for (var i = 0; i < data.Length; ++i)
data[i] *= scale;
var theta = B * sign * 2 * Math.PI / n;
var wjr = wpr;
var wji = wpi;
for (var j = 1; j <= n/4; ++j)
var k = n / 2 - j;
var tkr = data[2 * k]; // real and imaginary parts of t_k = t_(n/2 - j)
var tki = data[2 * k + 1];
var tjr = data[2 * j]; // real and imaginary parts of t_j
var tji = data[2 * j + 1];
var a = (tjr - tkr) * wji;
var b = (tji + tki) * wjr;
var c = (tjr - tkr) * wjr;
var d = (tji + tki) * wji;
var e = (tjr + tkr);
var f = (tji - tki);
// compute entry y[j]
data[2 * j] = 0.5 * (e + sign * (a + b));
data[2 * j + 1] = 0.5 * (f + sign * (d - c));
// compute entry y[k]
data[2 * k] = 0.5 * (e - sign * (b + a));
data[2 * k + 1] = 0.5 * (sign * (d - c) - f);
var temp = wjr;
// todo - allow more accurate version here? make option?
wjr = wjr * wpr - wji * wpi;
wji = temp * wpi + wji * wpr;
if (forward)
// compute final y0 and y_{N/2}, store in data[0], data[1]
var temp = data[0];
data[0] += data[1];
data[1] = temp - data[1];
else
var temp = data[0]; // unpack the y0 and y_{N/2}, then invert FFT
data[0] = 0.5 * (temp + data[1]);
data[1] = 0.5 * (temp - data[1]);
// do packed inverse (table based) FFT. This can be changed to regular inverse FFT to save memory
TableFFT(data, false);
// scaling - divide by scaling for N, then mult by scaling for N/2
//if (A != -1) // todo - off by factor of 2? this works, but something seems weird
var scale = Math.Pow(2.0, -(A + 1) / 2.0)*2;
data[i] *= scale;
/// <summary>
/// Determine how scaling works on the forward and inverse transforms.
/// For size N=2^n transforms, the forward transform gets divided by
/// N^((1-a)/2) and the inverse gets divided by N^((1+a)/2). Common
/// values for (A,B) are
/// ( 0, 1) - default
/// (-1, 1) - data processing
/// ( 1,-1) - signal processing
/// Usual values for A are 1, 0, or -1
/// </summary>
public int A { get; set; }
/// <summary>
/// Determine how phase works on the forward and inverse transforms.
/// For size N=2^n transforms, the forward transform uses an
/// exp(B*2*pi/N) term and the inverse uses an exp(-B*2*pi/N) term.
/// Common values for (A,B) are
/// Abs(B) should be relatively prime to N.
/// Setting B=-1 effectively corresponds to conjugating both input and
/// output data.
/// Usual values for B are 1 or -1.
/// </summary>
public int B { get; set; }
public LomontFFT()
A = 0;
B = 1;
#region Internals
/// <summary>
/// Scale data using n samples for forward and inverse transforms as needed
/// </summary>
/// <param name="data"></param>
/// <param name="n"></param>
/// <param name="forward"></param>
void Scale(double[] data, int n, bool forward)
// forward scaling if needed
if ((forward) && (A != 1))
var scale = Math.Pow(n, (A - 1) / 2.0);
data[i] *= scale;
// inverse scaling if needed
if ((!forward) && (A != -1))
var scale = Math.Pow(n, -(A + 1) / 2.0);
data[i] *= scale;
/// <summary>
/// Call this with the size before using the TableFFT version
/// Fills in tables for speed. Done automatically in TableFFT
/// </summary>
/// <param name="size">The size of the FFT in samples</param>
void Initialize(int size)
// NOTE: if you port to non garbage collected languages
// like C# or Java be sure to free these correctly
cosTable = new double[size];
sinTable = new double[size];
// forward pass
var n = size;
int mmax = 1, pos = 0;
while (n > mmax)
var theta = Math.PI / mmax;
// compute in a slightly slower yet more accurate manner
var wpr = Math.Sin(theta / 2);
wpr = -2 * wpr * wpr;
cosTable[pos] = wr;
sinTable[pos++] = wi;
var t = wr;
wr = wr * wpr - wi * wpi + wr;
wi = wi * wpr + t * wpi + wi;
mmax = istep;
/// <summary>
/// Swap data indices whenever index i has binary
/// digits reversed from index j, where data is
/// two doubles per index.
/// </summary>
static void Reverse(double [] data, int n)
// bit reverse the indices. This is exercise 5 in section
// 7.2.1.1 of Knuth's TAOCP the idea is a binary counter
// in k and one with bits reversed in j
int j = 0, k = 0; // Knuth R1: initialize
var top = n / 2; // this is Knuth's 2^(n-1)
while (true)
// Knuth R2: swap - swap j+1 and k+2^(n-1), 2 entries each
var t = data[j + 2];
data[j + 2] = data[k + n];
data[k + n] = t;
t = data[j + 3];
data[j + 3] = data[k + n + 1];
data[k + n + 1] = t;
if (j > k)
{ // swap two more
// j and k
t = data[j];
data[j] = data[k];
data[k] = t;
t = data[j + 1];
data[j + 1] = data[k + 1];
data[k + 1] = t;
// j + top + 1 and k+top + 1
t = data[j + n + 2];
data[j + n + 2] = data[k + n + 2];
data[k + n + 2] = t;
t = data[j + n + 3];
data[j + n + 3] = data[k + n + 3];
data[k + n + 3] = t;
// Knuth R3: advance k
k += 4;
if (k >= n)
break;
// Knuth R4: advance j
var h = top;
while (j >= h)
j -= h;
h /= 2;
j += h;
} // bit reverse loop
/// <summary>
/// Pre-computed sine/cosine tables for speed
/// </summary>
double [] cosTable;
double [] sinTable;
#endregion
// end of file
