I want to code this kind of program to let it run on Windows (we can perform this easily on Linux I know
Or Could you please suggest me another possible solution?
I intended to use FFPMEG but there was a problem with dshow device (FFMPEG couldn't find Stereo Mix even though I had updated DirectX, removed current Audio driver and installed Realtek HDA got from realtek.com on my windows 7 home premium)
By the way, I found a topic on PortAudio mailing list, Can you check it a little bit and tell me what I should do in C/C++ language?
I'm sorry I can't understand it thoroughly. I'm just a newbie to both PortAudio and WASAPI.
http://music.columbia.edu/pipermail/por ... 12639.html
Thank you for your help.
