In SelectionBar.cpp I need the length of the current track, thus the 'Audio Position' resulting from the 'Skip to End' knob being pressed.
Where can I find that info and how can I make that info available in the SelectionBar class?
Thanks for any suggestions!
jerome42
Where in code the length of current track can be found?
Re: Where in code the length of current track can be found?
Look for a variable:
t1
t0 is the beginning of the selection and t1 is the end of the selection; if the entire track is selected then
t0 = 0
(time zero) and
t1 = ( the timestamp of the final sample)
t1
t0 = 0
(time zero) and
Thanks Edgar for showing me the way to this code fragment which I could copy to and use in SelectionBar.cpp without any compiler problems:
The extra p->SkipEnd(true) line brought me the correct value for playRegionEnd;
Regards, jerome42
Code: Select all
AudacityProject *p = GetActiveProject();
if (p)
p->SkipEnd(true);
double playRegionStart, playRegionEnd;
p->GetPlayRegion(&playRegionStart, &playRegionEnd);
Regards, jerome42
