Hiya,
I'm trying to find the code for the ADPCM encoding but I'm kind of lost in the source - any hints on where to look?
Best regards,
happy
ADPCM encoding source
happytrooper
Re: ADPCM encoding source
I think that by default Audacity uses libsndfile for handling ADPCM encoding, (if FFMpeg is installed then it is possible to use that instead).
happytrooper
Thank you for your quick reply!
