Audio automation using audacity
Audio software developers forum.
sayantanroy86
Post by sayantanroy86 » Tue Aug 30, 2011 8:56 am
Hello All,
I am doing automation testing. Steps to be performed are:
1. I need to invoke Audacity programmatically
2. Start recording sound from the sound card.
3. Stop the capture and save the file in client drive.
Which Audacity APIs should I use for this automation process? Any inputs on hot to automate Audio testing using audacity should help.
Best Regards
-Sayantan
Edgar
Forum Crew
Re: Audio automation using audacity
Post by Edgar » Tue Aug 30, 2011 2:28 pm
AutoIt3 (a free Windows-based scripting app) can do this, I suspect other OSes have similar scripting apps. There is a pipe-based module (mod-script-pipe) which is somewhat experimental and the developer does not seem to be doing any work on it.
