I've turned down the Monitor volume all the way (green vu meter) but still get a slight echo when recording. The echo DOES end up in the final recording.
What can be done about this?
Echo When Recording
RoboticGenitals
Re: Echo When Recording
need a lot more info about what you are doing and how
if gain is down you should not be recording at all
so what is the echo *of* ??
RoboticGenitals
The gain on the MONITOR is all the way down, not the rec gain.
The echo is of the audio that is being input to the program. It is faint but noticeable. The echo is really bad when I have the monitor gain up-- then It doesn't echo to the point of feedback, but it sounds close.
I'm just not used to using Audacity. I have it on an older computer but am more used to Adobe Audition 3. What other information would be helpful?
EverythingRoboticGenitals wrote:What other information would be helpful?
What operating system? Which audacity version? What's your source? Are you recording from a mic? How is it connected to the computer? What recording device have you selected on Preferences? Do you have hardware or software playthrough on?
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
What are you recording? And where
? When you record in a mine or something I guess the effect is normal
