First: I want to use my winamp player into a track. As in I want to record on the fly the music thats playing in my winamp so I can then edit it. I want to do that without a mike. How can I do that?
Secondly: Does Audacity supprts the EZDrummer ? Im a vista user and try downloading the vst bridge 1.1 but then my audicity wont load. I have to uninstall and reinstall audacity again without that plugin. So… can I use EZ drummer, if so, how can I install the vst plugin in my vista computer?
Third: I want to use plugins, compression plugins. Where can i download free plugins so i can use those in my tracks -like reverbs, pannings and compression?
Last: Is there a nice tutorial i can use for this software?
if you’re on windows, set your Windows Mixer (record section) to record from “stereo mix” (may just be called “mix”, or “What you hear”)
Use the “filewriter” output in WinAmp to write the audio to disk as a wav file, then import it into Audacity.
Audacity does not support VST instruments (VSTi), however, if you can export from EZDrummer as a wav file, then you can import that into Audacity for editing and/or further processing.
There are loads of free plugins available from the Audacity web site - I’d recommend trying the LADSPA plug-in pack first. http://audacityteam.org/download/plugins
