Same volume or waves
Hi
I would like to ask if there’s any way to turn the waves the same hight. So the words in the audio would be the same volume?
I tried to normalize with 0.1 db and then hard clip by -6 and it helped but anyway to do it better without distorting the audio too much? In the example below I didn’t normalize or do hard clip
Loudness is more complicated than that: waves of the same height can be perceived as different volumes.
The latest version of audacity has “loudness normalization” which can make audios equally loud…
https://manual.audacityteam.org/man/loudness_normalization.html
Unless you want an obvious distortion effect, don’t use hard clip.
Use soft limit instead … Limiter - Audacity Manual
https://manual.audacityteam.org/man/lou > … ation.html
Okay the waves are different sentences. What I want to do is making the words of a sentense to the same volume if that’s the right word for it. So “I am happy” having the exact same volume.
Does that make sence?
Use soft limit instead … > Limiter - Audacity Manual
Fortunately, it did not create any distortion in the sound and the quality is the same. But can soft limit do the same?
