Hi every one.
I could use your help.
I am aware that many here do not believe in subliminals, or how they can work, but I know that you are ready to help anyway.
I would like to make a subliminal as well as a supraliminal
Subliminal Audios - Affirmations in high frequency, usually around 16000-17500 Hz which most adults can’t hear consciously but within the 20 - 20000 Hz range and hence detected by the ears. (masked/unmasked)
Supraliminal Audios - Affirmations in Low volume, masked by audio such that you don’t interpret the affirmations consciously even if you might hear them. (it is recommended that you hear whispers).
When it comes to subliminals:
- I heard that you don’t convert the audio file to 17500 Hz, so what actually happens? What is the difference between choosing 16500 or 17500?
What most people do is to “convert” their 44,100 Hz sound file to 17,500 hz and then use the original sound file to assess the sound level.
However, I saw in another comment that Steve referred to the following method:
What difference will it make?
I’ve also seen methods (that I can’t quite find) that first change the sample rate to 192000 Hz, then -1db, use .ny promt and then normalize to -23.
What difference will it make to a subliminal versus just converting it from 44,100?
The theory is "basically, when we say the affirmations are inaudible, it means that the human ear cannot hear the frequency because the auditory hair cells in your ear that are responsible for processing (hearing) this pitch have become very insensitive (usually a result of aging).
This is where the confusion occurs because so many people are led to believe that the brain can’t process something we can’t hear, and that is very incorrect. Your ears are responsible for hearing noises, but it’s the brain (auditory cortex) that’s responsible for processing and decoding the information.
Sound is what we hear while the brain interprets it. You can totally not hear something and still interpret it on a subconscious level. This is how subliminals work. Just because you can’t hear the affirmations doesn’t mean it isn’t being picked up by your brain. We know this because of the way sound waves work.
When you play the subliminal, you obviously won’t be able to hear anything, but does that mean the affirmations are just not there? Of course not. The sound waves are still there, causing your eardrums to vibrate where your brain processes and decodes these vibrations. The only difference is that your ears aren’t hearing it."
What I would like to ask for help with is:
Make sure the frequency is not too high. I saw in the analytics in Audacity that my highest frequency is almost 21000 Hz and make sure that the data is intact in the higher frequency.
In addition, I would like to hear what the difference is in the sound level when the frequency increases to avoid hearing damage.
2. As above, a supraliminal (masked) has the same effect as a subliminal, the advantage is that you can “hear” the messages, while the disadvantage is that they are not exactly “silent”.
The idea is to mask the affrmations recordings with ambient sounds BUT it must still be possible to hear the whispers/mumbling without it being possible to understand what is being said. This is because the sound waves must be strong enough to enter the ear, and if you mask the voices completely the effect will not be that great. I have done this successfully but the white noise I use is incredibly loud and I have difficulty finding a good balance. Besides this, there can be a difference in whether I can hear the words, depending on how loud I turn up the volume. Is there an option here to “lock in” the whisper/mumbles when I find the right volume, so no matter how much I turn it up or down, I only hear the whisper/murmur.
So how to mask the affirmation recording without getting hearing damage from a jet engine.
I saw this suggestion from DVDdoug but I don’t know if it has the same effect?
I hope you understand my questions, despite you guys being skeptical about it. So I need your professional objective help
