JSON Audio Sprite Data Exporter
Audio software developers forum.
Kitsune
Post by Kitsune » Tue Jan 26, 2021 6:18 pm
Hi there, I’m working on audio sprites and would like to use Software to automate the data exportation process.
I’m not very familiar with Audacity nor Nyquist so please correct me if I am wrong or when there is a better way :}
The data structure it would look like this
Code: Select all
"sheetName":{
   "spriteName":{
      [{"startTime": 0, "endTime": 3}]
Hopefully that’s valid JSON
Sheet name
- Sprite name
- Splice data
(There might be a lot of Splice data in one Sprite that is why it’s an array)
Kitsune
Re: JSON Audio Sprite Data Export
Post by Kitsune » Tue Jan 26, 2021 6:35 pm
I forgot to include other details
A Sprite Sheet is the entire Audio file
A Sprite is a group of related Sounds
A Splice contains data (startTime and endTime)
I am thinking that it could be a good option to use region label for Sprites and point label for Splices
If there is always a 1 second gap between each Splice and a 2 second gab between each Sprite it would be easy to tell them apart
I am familiar with lua so if you could point me to the right direction I can probably write my own software for this
Re: JSON Audio Sprite Data Exporter
Post by steve » Tue Jan 26, 2021 7:01 pm
It isn't ;)
Perhaps you mean:
Code: Select all
   "sheetName": [
         "spriteName": [
               "startTime": 0,
               "endTime": 3
I don't understand where Audacity fits in. What do you want Audacity to do?
Kitsune
Post by Kitsune » Tue Jan 26, 2021 9:11 pm
I want to use Audacity to visually label each Sprite and Splice and then use a plugin to read that data then export it as a JSON file
Post by steve » Tue Jan 26, 2021 11:21 pm
If you had a list of "Splice times" like this:
Code: Select all
0.000000	2.890884
7.151746	11.261678
19.504762	31.021859
42.353197	53.963175
63.529796	69.845624
would that be sufficient to allow you to write a lua script to generate your JSON?
The above example was created by exporting a label track that contained 5 "region labels".
See: https://manual.audacityteam.org/man/label_tracks.html and https://manual.audacityteam.org/man/imp ... abels.html
Kitsune
Post by Kitsune » Wed Jan 27, 2021 12:49 am
I’d still need the Sprite name and Sheet name to construct the data
The JSON data would be converted into a Lua table
Something like that
Post by steve » Wed Jan 27, 2021 9:38 am
What determines those names?
Kitsune
Post by Kitsune » Wed Jan 27, 2021 9:45 am
Would probably use region label for Sprites and point label for Splices?
I’m not sure if you can assign text to labels but I’d assume so
Post by steve » Wed Jan 27, 2021 10:32 am
Yes you can. See the links to the manual that I posted previously.
Kitsune
Post by Kitsune » Fri Jan 29, 2021 2:12 am
I see that is a very useful feature, thank you for pointing it out!!
It is nice that I can export the start time and end time of each region label, however is there a way their names could also be exported as well?
Or maybe read by another program as a project file and then export the data as a Lua file?
The track name or file name would be the Sheet name, -> file name
Each Point Label would be the Sprite name, -> Contains Splices
Each Region Label would contain Splice data, -> start and end time
While the default export format is helpful it still requires human input which I would like to avoid, however if this isn’t possible then it’s fine.
