Widget to display waveform.
Audio software developers forum.
apoorv569
Operating System: GNU/Linux other
Post by apoorv569 » Sun Nov 22, 2020 8:09 pm
I'm making a application using wxWidgets, and as Audacity also used wxWidgets for GUI toolkit, I wanna know which widget Audacity uses to display the waveform when you load a audio file to it.
Sorry if this is the wrong board to ask such question.
Re: Widget to display waveform.
Post by steve » Mon Nov 23, 2020 11:24 pm
The drawing of the waveform in Audacity is rather complex. You can view the code here: https://github.com/audacity/audacity/bl ... Artist.cpp
jademan
Forum Crew
Post by jademan » Sun Nov 29, 2020 7:33 pm
From https://wiki.audacityteam.org/wiki/Developer_Guide
"The GUI code is mostly written using wxWidgets library, which handles dialogs and common GUI controls. HOWEVER, the waveforms (in the TrackPanel) is not a standard widget, and Audacity code draws the TrackPanel itself, placing the lines and text and clickable icons."
