Importing Raw Data into Audacity
Audio software developers forum.
dnelson
Post by dnelson » Mon Aug 03, 2020 4:07 pm
hello.
I'm using Audacity to import RGB data as Raw data. I was wondering how does the raw import determine frequency and amplitude for a sample? Does it sample each pixel, row or column?
Thx
Re: Importing Raw Data into Audacity
Post by kozikowski » Mon Aug 03, 2020 5:01 pm
import RGB data
You know this is an audio program, right? Not picture or video.
Raw is an adventure. You have to tell it all the stuff that normally appears in the file header. It assumes the file header is damaged and can't be read.
So it sees a pile of unformatted data. Have a good time.
I've never done it but I believe it takes your word on it. It just blindly opens up the data according to what you told it.
Post by steve » Mon Aug 03, 2020 5:03 pm
The "sample rate" is set in the Import RAW dialog.
The "audio frequency" is determined by the relationship of one sample to the adjacent samples.
The "amplitude" of a sample is the sample's numeric value.
Example:
If the data is (decimal representation):
Code: Select all
0   0.5   0   -0.5   0   0.5   0 ....
Then the amplitude is +/- 0.5 and the frequency rate is 1/4 of the sample rate.
