Subliminal Audio with Inaudible Human Voice Affirmations
Audio software developers forum.
friends2me
Operating System: Windows 7
Post by friends2me » Sun Feb 10, 2019 2:36 pm
hi,
Request : Subliminal Audios with Positive Affirmations App (Software)
- Record human voice or Use already recording affirmations file.
- Mix it with music (masking) so lister only listen music while the affirmations go to sub conscious.
- Copy paste the affirmatins to match the length of the music file.
- increase the length of music by copy paste to 30 minutes as healing music is normally 5 minutes.
- As affirmations are recorded by humans so the gap b/w 2 affirmaitons are not fixed, this software should
give the facility to make a constant gap of 4 or 5 seconds b/w 2 affirmation sentences.
- Can add Alpha and Theta sound waves to music track or the final track.
- Can add Isochronic tones to music track or the final track.
- Can add binaural beats to music track or the final track .
- Fade in Fade out option
- Masking and Reverse Masking option
- Ability to make make 432 hz music or convert the final Audio to 432 hz & 528 hz.
- As should be an option to make an exact gap of 4 or 5 second b/w two sentences (affirmations).
- or simply make a Tutorial on how to make subliminal audios using Audacity, Sound wave and Adobe Edition
in text, images and video form & make a small app of it of 1 dollars.
there are about 50 million people who listen Subliminal Healing Music with Affirmations.
famous sites are Vortex Success, Sprudio and Mind movies......
hope you work on that software.
regards
Re: Subliminal Audio with Inaudible Human Voice Affirmations
Post by steve » Sun Feb 10, 2019 2:53 pm
If you search this forum, you will find discussions and "How To's" about most of these items.
Tip: Search Google with search terms in this form:
Code: Select all
site:https://forum.audacityteam.org subliminal
