Normalize to linear amplitude
Anything you think is missing, or needs enhancement, goes here.
Piotr Grochowski
Post by Piotr Grochowski » Thu Apr 12, 2018 6:39 pm
Request: Normalize that uses volume instead of dB.
Reason: Topic split and given relevant title
Contact:
Re: Normalize to linear amplitude
Post by steve » Fri Apr 13, 2018 12:10 pm
Here you go.
This plug-in requires a recent version of Audacity and is designed for mono tracks only.
If this does what you want, it would be simple to modify it to also support stereo tracks.
normalize-linear.ny
Updated plug-in
(359 Bytes) Downloaded 30 times
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 5:37 am
Not only I had to log out to download this, but it gives me an Error when I try to enable it in 32-bit Audacity 2.2.2 for Microsoft Windows on Windows 10. Is that a 64-bit plugin?
Contact:
Post by steve » Sat Apr 14, 2018 10:06 am
Piotr Grochowski wrote:it gives me an Error when I try to enable it
What's the error?
Piotr Grochowski wrote:Is that a 64-bit plugin?
No. Nyquist plug-ins are written in 7-bit ASCII (plain text), and processing is done by the 32-bit Nyquist interpreter which is built into Audacity, so Nyquist plug-ins are platform independent.
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 11:08 am
What's the error?
Ill–formed Nyquist plug–in header
Contact:
Post by steve » Sat Apr 14, 2018 11:19 am
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 11:24 am
Once again, I had to logout out to be "authorized" to download it. But thanks, now I have a perfectly working pair of Amplify and Normalize effects that don't require input to be encrypted with the "dB" algorithm, and have unlimited number of decimal places.
Contact:
Post by steve » Sat Apr 14, 2018 11:56 am
Piotr Grochowski wrote:Once again, I had to logout out to be "authorized" to download it.
I've adjusted that so that you can now download files while logged in.
