Sample level n-pass filter
Anything you think is missing, or needs enhancement, goes here.
Piotr Grochowski
Post by Piotr Grochowski » Thu Apr 12, 2018 6:35 pm
An n-pass filter is a filter that reduces certain frequencies.
A sample level filter is a filter that only checks neighboring samples by a small amount.
Sample level low-pass filter: An output sample x are input samples (x-1)×0.25, (x)×0.5 and (x+1)×0.25 added together. There is a checkbox for x-1 and x+1 to overflow (first-1=last, last+1=first).
Sample level high-pass filter: An output sample x are input samples (x-1)×-0.25, (x)×0.5 and (x+1)×-0.25 added together. There is a checkbox for x-1 and x+1 to overflow (first-1=last, last+1=first).
Piotr Grochowski
Re: Sample level n-pass filter
Post by Piotr Grochowski » Fri Apr 13, 2018 5:21 am
And it is impossible to reproduce with current Audacity, as there isn't any exact volume input in Normalize (the dB input is limited to 2 decimal places, not even 16-bit precision; please implement more decimal places AND an unencoded volume input).
Piotr Grochowski
Post by Piotr Grochowski » Fri Apr 13, 2018 10:48 am
In fact, it's possible to generalize these sample-level n-pass filters, producing a family of n-pass filters that work by duplicating, shifting, amplifying and combining.
For example, here is a cosine generalization that is essentially twice the size of the original sample-level low-pass filter: (x-3)×0.03661165, (x-2)×0.125, (x-1)×0.21338835, (x)×0.25, (x+1)×0.21338835, (x+2)×0.125 and (x+3)×0.03661165 added together.
What will happen, if a sinc generalization is used?
Contact:
Post by steve » Fri Apr 13, 2018 2:08 pm
If you really want to do this sort of thing, you need to use MatLab, or Octave, or Nyquist.
Of those three, Nyquist is by far the easiest to learn and use, and it is built into Audacity.
The other two are unrelated to Audacity, and have their own support channels.
Looking at your original post, if we ignore the bit about "overflow", then it is a kind of averaging filter that may be achieved in just a few lines of Nyquist code.
These examples can be run in the Nyquist Prompt effect, and require a fairly recent version of Audacity. They are not full plug-ins, though they could easily be made into full plug-ins, but are to illustrate how you would approach this type of task in Audacity. I don't use MatLab or Octave, so I can't help with either of those.
Code: Select all
;version 4
;control type "Filter type" choice "Low pass,High pass" 0
(setf type (1+ (* type -2)))
(defun filter (sig)
  (let ((d (/ len)))
    (sum
      (mult type 0.25 (extract (* 2 d) 1 sig))
      (mult 0.5 (extract d 1 sig))
      (mult type 0.25 sig))))
(multichan-expand #'filter *track*)
If all you are interested in is the frequency response of the filter, then it is even easier:
Code: Select all
;version 4
(if (= type 0)
    (lowpass2 *track* (/ *sound-srate* 4) 0.57)
    (highpass2 *track* (/ *sound-srate* 4) 0.57))
It gets a little more complicated to add the "overflow" samples, and in most cases it will just create a click at the start and/or end, but it can be done like this:
Code: Select all
;version 4
;control loop "Loop boundary values" choice "Yes,No" 0
(defun sample (val)
  (snd-const (* type 0.25 val) 0 *sound-srate* (/ *sound-srate*)))
(defun sampleval (sig n)
  (if (= loop 0)
      (abs-env (sref sig (/ n *sound-srate*)))
      0))
(defun filter (sig)
  (let ((d (/ len))
        (first (sampleval sig 1))
        (final (sampleval sig (1- len))))
    (if (= loop 0)
        (sum
          (sample final)
          (at-abs (/ (- len 1) *sound-srate*) (cue (sample first))))
        (sum
          (mult type 0.25 sig)))))
Piotr Grochowski
Post by Piotr Grochowski » Fri Apr 13, 2018 6:22 pm
The purpose of the integer overflow for these filters is to allow seamless processing on loops.
Contact:
Post by steve » Sat Apr 14, 2018 10:01 am
Piotr Grochowski wrote:The purpose of the integer overflow for these filters is to allow seamless processing on loops.
Normally one would process the audio before making the loop.
If you are starting with a seamless loop and you want to apply effects, then a useful technique is to to repeat the loop 2 times (total of three times, then apply the effects, then make a new loop from the middle 1/3rd. This technique works with most effects, without requiring specially modified effects.
Piotr Grochowski
Post by Piotr Grochowski » Sat Apr 14, 2018 11:18 am
What about existing songs that are loop–friendly? What about generated noise?
steve wrote: If you are starting with a seamless loop and you want to apply effects, then a useful technique is to to repeat the loop 2 times (total of three times, then apply the effects, then make a new loop from the middle 1/3rd. This technique works with most effects, without requiring specially modified effects.
Isn't it more convenient to have a loop–friendly effect in the first place?
With your percentage amplification effect written in Nyquist, it becomes possible to reproduce the sample–level n–pass filters and other n–pass filters that work by duplicating, shifting, amplifying and adding: duplicate the song to make it triple, shift the second song one sample to the left (or cut a sample from beginning and paste at the end for the loop–friendly variant), shift the third song one sample to the right (or cut a sample from the end and paste at the beginning for the loop–friendly veriant), amplify the first song to 50%, amplify the second and third songs to 25% and Mix And Render.
Contact:
Post by steve » Sat Apr 14, 2018 11:24 am
Piotr Grochowski wrote:Isn't it more convenient to have a loop–friendly effect in the first place?
That depends on whether you expect someone else to convert the effects to "loop friendly" for you, or if you convert them yourself. If you expect someone to do it for you, you are likely to be waiting a very long time. If you do it yourself, then you may find it easier to apply effects either before making the loops, or after mixing down the looped track.
