Sticky Amplify
Anything you think is missing, or needs enhancement, goes here.
Sticky Amplify
Post by kozikowski » Tue Apr 03, 2018 6:42 pm
I had occasion to use Amplify a bunch of times at the same setting. Amplify settings aren't sticky. Alternately, is there a Drag-Select > Mute which was the actual goal.
Trebor
Re: Sticky Amplify
Post by Trebor » Tue Apr 03, 2018 7:32 pm
kozikowski wrote:I had occasion to use Amplify a bunch of times at the same setting. Amplify settings aren't sticky.
On Windows, Audacity 2.2.1, (and previous versions), "Ctrl"+"R" will repeatedly apply Amplify with the same gain setting.
You'll have to remember what that setting was, as if you select Amplify from the menu again, the old gain value will be overwritten.
Contact:
Re: Sticky Amplify
Post by steve » Tue Apr 03, 2018 7:52 pm
kozikowski wrote:Alternately, is there a Drag-Select > Mute
There is "Drag-Select -> Edit menu > Remove Special -> Silence Audio" (Ctrl + L)
Contact:
Re: Sticky Amplify
Post by steve » Tue Apr 03, 2018 7:54 pm
If it's about this topic: viewtopic.php?p=345398#p345398
then there is the "Pop Mute" plug-in http://wiki.audacityteam.org/wiki/Nyqui ... s#Pop_Mute
Re: Sticky Amplify
Post by kozikowski » Wed Apr 04, 2018 4:23 am
Yes, but.
The track has AGC on the performance and there is no unique firework pop. The explosion is a blob of highly distorted waveforms that slowly reveals the music as the AGC comes down from the ceiling. Note the music is throbbing bass rock and many if not all of the bass notes overload.
It's not recoverable.
I'm betting those performances are lip sync and you could buy the music in the "Main Street Emporium." For money.
Contact:
Re: Sticky Amplify
Post by steve » Wed Apr 04, 2018 10:50 am
kozikowski wrote:It's not recoverable.
I agree.
