Enhancement Request Import Raw
Anything you think is missing, or needs enhancement, goes here.
roadsterUK
Post by roadsterUK » Tue Apr 03, 2018 5:16 pm
Within import/importraw.cpp is an arbitrary limit on the maximum sample size which can be specified at 100,000.0 .Any import above that is of course miss-timed. I have tested that this limit can be removed and successfully imported raw data at 384,000 Hz sample size. Could I request that the limit be set at 768,000 which would provide an element of future proofing.
Thanks.
Contact:
Re: Enhancement Request Import Raw
Post by steve » Tue Apr 03, 2018 6:15 pm
I think 384 kHz is already pretty "future proof" as it's a ridiculously high sample rate for audio.
As the highest preset sample rate is 384 kHz, I think it is reasonable to match that in "Import Raw", so I've done that. So long as there are no objections from others in the development team, that will be in the next release.
