possible to batch edit 17,000 slightly different .mp3 files?
Anything you think is missing, or needs enhancement, goes here.
Edgar
Forum Crew
Operating System: Windows 7
Contact:
Re: possible to batch edit 17,000 slightly different .mp3 fi
Post by Edgar » Tue Mar 27, 2018 9:32 pm
This is my custom effect:
this is my custom Preferences:
-Edgar
compiling Audacity daily
64-bit Windows 7
aud-dude
Post by aud-dude » Fri Mar 30, 2018 11:15 pm
You all are amazing. Forgive my delayed reply, please. I've hit a few walls (outside of this project). In this project, though, we're not even figuring out how to run Macros in the Mac version. Screenshots we're finding seem to correlate to other versions.
waxcylinder
Post by waxcylinder » Sat Mar 31, 2018 9:47 am
aud-dude wrote: ... we're not even figuring out how to run Macros in the Mac version. Screenshots we're finding seem to correlate to other versions.
The images on these pages should be reasonably up to date - they're certainly not old 2.2.2 and earlier Chains images:
https://alphamanual.audacityteam.org/man/Manage_Macros
https://alphamanual.audacityteam.org/man/Apply_Macro
The examples page, however, is out of date: https://alphamanual.audacityteam.org/ma ... s_Examples
I'm not going to change that until I'm certain that the GUI dialogs for Macros have stabilized,
Once you have added that Macro I (and James) built for you earlier to the Macros folder and then restarted Audacity - then use File > Macros ... and you should see the Manage Macros dialog (as in the first link in this post),
You should see the new Macro in the list in the left box, click on it to highlight it. You will then see the Macro listed in the box on the right (just for information - you don't need to edit it or anything)
Then all you need to do is use either the Project or Files button to apply the Macro.
It may be simpler to start testing buy running it an open project first so you can see the result - just open Audacity import one of your files and apply the Macro as above.
Then if that works, and your happy with the result, create a test folder with 3 or 4 test files from your set - and try using the apply to Files.
