audio bus
Anything you think is missing, or needs enhancement, goes here.
audio bus
Permanent link to this post Posted by prko » Wed Feb 28, 2018 1:03 am
Hi,
It would be great if Audacity would have an audio bus.
Then several tracks can route the signal to the specific audio bus, and the signal from the audio bus can be routed to the master bus.
Do you have any plan to implement the audio busses?
prko
Re: audio bus
Permanent link to this post Posted by steve » Thu Mar 01, 2018 10:24 am
There are currently no plans to implement audio busses. While audio busses are extremely useful features of "real-time DAW" applications, they are not really very useful for "wysiwyg" audio editors (like Audacity). The beauty of audio busses in a DAW is that you can pre-mix specific channels and route them through an effect chain, but Audacity does not have real-time effect chains. In Audacity, effects are applied directly and immediately to the selected audio. What you can do in Audacity, is to select multiple tracks and apply an effect simultaneously to the selected tracks.
Re: audio bus
Permanent link to this post Posted by prko » Thu Mar 08, 2018 10:45 am
Thank you for your kind answer and useful tips.
prko
Return to Adding Features to Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
