why there is no effects check box (list ) !!
Anything you think is missing, or needs enhancement, goes here.
Permanent link to this post Posted by unknown7 » Wed Feb 14, 2018 9:51 pm
audacity : serious question , why there is no effects check box (list ) like any other paid software! why it can not be in open source software ! that is not an order or demand it
just why?!
i know it is free and open source thanks but why?
why you just did not put a check box list for effects that u used for example , you used a EQeffect+reverb invert etc ! and you want to use them as same! on other voice track
or want to disable it customize it make it preset! .. that is the powerful thing you can do to audacity ! for now , future and should did in past ,!
hope i get a logical answer!
thanks
unknown7
Re: why there is no effects check box (list ) !!
Permanent link to this post Posted by waxcylinder » Thu Feb 15, 2018 8:41 am
unknown7 wrote:why you just did not put a check box list for effects that u used for example , you used a EQeffect+reverb invert etc ! and you want to use them as same! on other voice track or want to disable it customize it make it preset!
Effects that have settable parameters have a Manage button - clicking ob this will show a dropdown menu.
You can use the Save Preset to save and name the current settings you have for that effect. You can create many different ones if you want/need.
You can subsequently use the User Presets to recall any of those user settings for the effect.
Some effects (and these include EQ and Reverb that you mention) also have factory presets to choose from
1) for Reverb use the Manage button and then the Factory presets and you will be presented with a dropdown list
See this page in the Manual: https://manual.audacityteam.org/man/reverb.html
2) for Equalization use the Select Curve button to access the factory presets - with EQ you can either use the Save/Manage curves button or the Manage > Save Preset to save user presets
See this page in the Manual: https://manual.audacityteam.org/man/equalization.html
The Factory presets for all effects always has an option to restore Defaults so you can revert to the original factory settings.
waxcylinder
Permanent link to this post Posted by unknown7 » Thu Feb 15, 2018 7:27 pm
thanks waxcylinder, i know that but i was talking about effects box , all effects you use you can make them a preset! not every one alone ,
for example! you add more than 5 effects and you want to disable the first one without going back !
for what i mean and for example in mixcraft ,mixpad in a lot of softwares ! and all paid
that is why i said why it can not be in open source software !?
FX check box!
unknown7
Permanent link to this post Posted by steve » Thu Feb 15, 2018 9:11 pm
Audacity has "Chains" http://manual.audacityteam.org/man/chai ... ation.html
Is that what you mean?
Permanent link to this post Posted by steve » Thu Feb 15, 2018 10:29 pm
Or perhaps you are referring to real-time effects, in which case, take a look at Ardour: https://ardour.org/
Permanent link to this post Posted by unknown7 » Fri Feb 16, 2018 2:28 am
thanks steve, for mention ! "chain" ! it is good and saving time ! hope it was more dynamic like the example ! but better than nothing hope the future development focus on that ! because the questions still why can not be ?! and i read a topic " that there no real-time for effects even some have alive review !
-so hope all effects have alive review plus the check list box ! but i am not a developer and i am not the developer here! -
and like the real time effects , i tried Ardour too but did not focus on it , for now ,,
unknown7
Permanent link to this post Posted by waxcylinder » Fri Feb 16, 2018 10:22 am
unknown7 wrote:thanks waxcylinder, i know that but i was talking about effects box , all effects you use you can make them a preset! not every one alone
Ah I see what you are driving at now ...
A while back we did some experiments with an Effects Rack which I think was to do the job you describe - but the development was experimental only and never finished (and the developer for that no longer works on the project).
waxcylinder
Permanent link to this post Posted by unknown7 » Sun Feb 18, 2018 7:45 pm
waxcylinder, done until we meet again in another topic !
unknown7
Return to Adding Features to Audacity
Who is online
