dB Waves
Anything you think is missing, or needs enhancement, goes here.
dB Waves
Post by kozikowski » Tue Jan 09, 2018 9:14 pm
I haven't seen this posted in a dog's age.
Kill the blue wave Percent Scale.
This one's practically a "gimme." Simple graphic change with straightforward, apparent benefits. I'm sure there are dependencies here and there, but compared to the current crop of Audacity problems, this should be a stroll in the park. Something that could be tackled, say, before lunch.
I do not like working in Waveform (dB) because most important sound management (except noise) happens in the top 24dB. Perfect for linear waves.
Trebor
Re: dB Waves
Post by Trebor » Tue Jan 09, 2018 9:55 pm
kozikowski wrote:I do not like working in Waveform (dB) because most important sound management (except noise) happens in the top 24dB...
Can zoom-in the loudest 24dB ...
Re: dB Waves
Post by kozikowski » Tue Jan 09, 2018 10:22 pm
That's only the top of the waveform.
In case you missed the conversion, Audiobook readers need to set their recording peaks between 50% and 34%.
"Let's see, put down 1/3, times twenty log 10....."
Old Cool Edit graphic screen capture.
Re: dB Waves
Post by kozikowski » Wed Jan 10, 2018 1:08 am
The fake graphic only has the positive-going waves because I wasn't up to Photoshopping all the values between the two zero points. That and I think -24 is actually in the wrong place. It's a free-hand illustration.
I did discover one dependency. Generate > Tone is in Percent. Others may be, too.
"Make a -20dB tone."
"Sure. Let's see. Divide by Log 10..... No, wait. Divide by 20 ...."
