Vertical line needed when cursor is on waveform
Anything you think is missing, or needs enhancement, goes here.
Permanent link to this post Posted by seanspotatobusiness » Sat Jun 10, 2017 8:29 am
In the top picture, the cursor is on the thing along the top with the time and a useful vertical line appears on the waveform which tells me where my cursor is in the waveform. In the bottom picture, the cursor is on the waveform and no vertical line appears which leaves me guessing exactly where my imminent selection is going to start. I'd like a vertical line when my cursor is on the waveform! Thanks.
Reason: used local copy of imaɡe -̩ remote is not displayinɡ
seanspotatobusiness
Re: Vertical line needed when cursor is on waveform
Permanent link to this post Posted by Gale Andrews » Sat Jun 10, 2017 12:04 pm
By "cursor" do you mean "mouse pointer"?
Permanent link to this post Posted by seanspotatobusiness » Mon Jun 12, 2017 2:44 pm
Yes, the mouse pointer.
seanspotatobusiness
Permanent link to this post Posted by Edgar » Tue Jun 13, 2017 2:23 pm
+1
-Edgar
compiling Audacity daily
64-bit Windows 7
Edgar
Forum Crew
Operating System: Windows 7
Permanent link to this post Posted by Gale Andrews » Wed Jun 14, 2017 10:59 am
You can see where the selection starts/ends if you drag a rough selection in the waveform then adjust the selection edges.
Permanent link to this post Posted by cyrano » Wed Jun 14, 2017 6:57 pm
+1
cyrano
Return to Adding Features to Audacity
Who is online
