Some problems, applying Bass and Treble.
After clicking for this effect appears (strange view of the effect window):
I must click "apply". But after applying the picture doesn't disappear, I must click "close". Please, correct.
Re: Some problems, applying Bass and Treble.
For other effects there is OK instead of "apply". For instance (standart view):
Audacity 2.3.1-alpha-June 19 2016.
Robert J. H.
That's all correct behaviour.юра00 wrote:After clicking for this effect appears (strange view of the effect window):
The effect has now real-time preview. It acts exactly as e.g. Vst plug-ins.
You can adjust sliders on the fly while listening which is very convenient. You can even navigate to the main window, change the selection, the start position of the playback, invoke loop playback etc.
The effect stays open after applying (in order to select another region or track), close it manually with the button or with the escape key (remember that alt-F6 brings the effect into view again).
Robert
Windows of all other effects close, after applying. It is uncomfortable clicking 2 buttons instead of 1. Please, make, as before, in 2.1.2. Аt first everything was fine. But since some alpha 2.1.3 version, effect window has changed to unusual, unwonted, unlike from other effects view.
- Quality Assurance
There is no 2.3.1 version.юра00 wrote:Audacity 2.3.1-alpha-June 19 2016.
Alpha builds are just that - not releases and not stable. Don't use them unless you know what you are doing and accept the risks. If you want to help us by testing alpha releases, that is greatly appreciated, but if so update to each new alpha build as it comes out. You can get RSS or e-mail alerts for every new Windows alpha build.
- Quality Assurance
Moved to "Adding Features".юра00 wrote:Windows of all other effects close, after applying. It is uncomfortable clicking 2 buttons instead of 1. Please, make, as before, in 2.1.2.
Of course, Bass and Treble won't go back to being a non-real-time preview effect. You can use Equalization instead, which is not yet real-time preview.
We have discussed the possibility of adding an "Apply and Close" button or perhaps add a checkbox "Close on Applying". Both would make the effect dialogue wider.
Certainly, I kept in mind 2.1.3 version. Thank you!
As you consider good idea - add a checkbox "Close after applying".
I've downloaded the latest audacity alpha 23 october 2016 version,the button "close on applyiig" still doesn't appear. Is it hard to do? Thank you in advance!
- Quality Assurance
We have almost no active developers at the moment, so we can make no guarantee that we will make any changes in the near future.юра00 wrote:I've downloaded the latest audacity alpha 23 october 2016 version,the button "close on applyiig" still doesn't appear. Is it hard to do? Thank you in advance!
