That would be very helpful. Because I don't mind the extra scrolling, what matters to me is being able to see both adjustment-levelers; Gain & Pan.Gale Andrews wrote: Do you want to request a setting that makes all tracks default height? It would mean much scrolling up and down in a project with many tracks.
Make all tracks same height
Split from http://forum.audacityteam.org/viewtopic ... 10#p313010
- So having an option (along with a hotkey to do-so) to set all tracks to default view would save me the time & hassle and it's a function within Audacity so it makes sense for this revert-back-option to exist.
- Quality Assurance
- Operating System: Windows 10 / 11
Re: Make all tracks same height
If we added what you request, I think we would offer a custom height for mono and stereo tracks to use as the default. So your default could be taller or less tall than our default.
Note that there is a keyboard method of opening the gain or pan slider for the focused track (the one with the yellow border), even if the sliders are invisible. Use UP or DOWN arrow to move the focus border to the required track, then SHIFT + G to open the gain slider or SHIFT + P to open the pan slider.
+1 - for both - adding a set* of default heights to preferences & a menu item (?) for quick access to set all tracks to default height.Gale Andrews wrote:If we added what you request, I think we would offer a custom height for mono and stereo tracks to use as the default. So your default could be taller or less tall than our default.
* don't forget, there are more types of tracks than just audio (label, note etc.)
PS – a while back, when we were playing with something else, I gave my users the start of something like this: The only track type with which I dealt was the Label Track. If I were going to add others I would reverse the position of the next two sections (Snap To & Pan/Gain), make an Audio Track section (which would include Pan/Gain) which would be moved above the Track section as well as any other necessary sections for track types desired.
I would add the access activator to the View menu in the section containing Expand/Contract All Tracks.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
