Adding VST'S
Hi, thank you for 3.2.4 and all your great hard work! Would it be possible in a future update, that I cold nominate where I store my VST3/VST2 on my PC. A different location/Hard drive? Thank you for your time, have a great day. Regard’s, Joseph. :heart:
This will be possible eventually but isn’t the highest priority right now. In the meantime, you can create a Junction in one of the standard paths, or change the registry entry for VSTPluginsPath in HKEY_LOCAL_MACHINE\SOFTWARE\VST (the latter also would have the benefit of defaulting any future plugin installations to this path)
:+1: Thank you for your reply. Regard’s, Joseph.
