Hi,
we are using label tracks to annotate audio files in Audacity, and I have a feature request.
(I’m not sure if this is the right place to ask for it, or if the GitHub issue tracker is also actively read for new FRs)
It would be nice if you could drag and drop a previously exported label (track) file onto an open Audacity project.
The drag and drop handling could check the file extension (or maybe check if the file’s contents is pure text with 3 tab-separated columns), and then add the labels as a new label track in the project.
If you drag and drop both a(n) (set of) audio file(s) and a (set of) label file(s), they would all be added as audio tracks or label tracks.
I know you can go through File → Import → Labels… but that’s not so user-friendly.
Thanks for considering this.
(and if you prefer that I add a ticket on GitHub, let me know)
Koen
