To try and address these issues, I have written a macro which automates most of the process.
- First the macro must be imported into "Manage Macros".
(See: https://manual.audacityteam.org/man/manage_macros.html) - Then check that Audacity is set up to record it's own output, as described in "latency test".
(See: https://manual.audacityteam.org/man/latency_test.html in the Audacity manual) - Set the recording level quite high so that the maximum recording level will be close to full track height (0 dB)
- Then, in an empty project, run the macro.
If all goes well, it should automatically set latency compensation correctly.
Note that with consumer grade audio hardware it is normal for latency to be a bit different on each run, but should be within about +/-1 millisecond. This macro takes the average of 5 runs and sets latency compensation accordingly.
I've only tested on my own (Linux) computer, and for me it works very reliably. If it works well for others I'll suggest to the dev team that the add it to the next release. Please try it and post your results / reviews here.
(see next post for updated macro.)
