Hello.
Please, could You add to Audacity feature (specially to Windows Audacity) searching keyboard shortcuts by pressing key shortcut? For example I would like to bind key to one action, but I don’t know, if this key shortcut was used for another action. It’ll be easy for me to know keyboard shortcuts, which I can’t used for certain actions.
Thank You.
Best regards
Marco Oros
The Manual has a full list of keyboard shortcuts:
https://manual.audacityteam.org/man/keyboard_shortcut_reference.html
Beware there are two sets of shortcuts provided:
1) Standard
This is the default set - it is cut down to provide more free keys for users’ custom settings
2) Full
This is really provided for VI users (and keyboard warriors) a more complete set
What I usually do is try a key or key combination in Keyboard preferences - Audacity will then tell you
a) if that key is already in use, and
b) ask if you want to overwrite that with your new shortcut key binding.
Peter.
Thanks.
I have finally found in radio button one, that says find keys by shortcut. After that I have pressed shortcut and I have finally find this shortcut. If list is empty, It means, that I can use this shortcut for another action, because this shortcut is not uses.
Thanks for that update Giovani,
Peter
