fine tune latency correction effect
Anything you think is missing, or needs enhancement, goes here.
specialbat
Post by specialbat » Sat Feb 13, 2021 8:32 pm
I'm finding when overdubbing the resulting track always has to be fine tuned very small amounts with time shift no matter how well I try to set the value in prefs -> "latency compensation".
That neccessitates zooming in and using the mouse to time shift. You can't see the value you started with and have to trial & error several times, listening to see if it sounds ok.
I would like this to be an effect like the "change tempo" where everything you need to make very small adjustments is right there and has preview
Unique
Re: fine tune latency correction effect
Post by Unique » Wed Mar 31, 2021 2:47 pm
I think something long these lines is needed since linux has the problem of variable latency between sessions.
Maybe and auto-latency test that the user can run to get the latency and set it befoe starting to record?
I think Ardour has something like this.
Post by steve » Wed Mar 31, 2021 3:12 pm
That's more likely when you use PulseAudio due to multiple layers of buffering. If you use Jack Audio System the latency should be exactly the same every time.
