Add an option to the sound finder of minimum sound length.
Parameters:
- sound length
- keep short sounds with: before; auto; after.
keep with Auto would keep short sounds with the sound block which is closest (shortest silence period).
When I’m preparing recorded talks for publishing, I clip them into sound segments then edit each segment separately. At least half the segments are very short (less than 1 sec) as found by the Sound finder tool and are not independent - they’re either part of the sound segment before or after.
This would automate the process of creating coherent sound segments from these recordings.
