Allow configuring mouse wheel to scroll horizontally
Anything you think is missing, or needs enhancement, goes here.
audentis
Post by audentis » Tue Mar 12, 2019 11:03 am
Greetings,
Currently the mouse actions are not configurable.
However, I'd like to scroll horizontally with the mouse wheel and use control+mouse wheel to zoom in and out.
Thanks in advance!
Re: Allow configuring mouse wheel to scroll horizontally
Post by steve » Tue Mar 12, 2019 11:44 am
"Shift + Mouse wheel" to scroll horizontally.
"Ctrl + Mouse wheel" to zoom.
Most users find these bindings to be useful, and with a little practice, easy to use. Although it should be "possible" to change these key bindings, doing so could have unwelcome consequences because scroll behaviours are bound to multiple actions. For example, mouse wheel scroll is bound to scrolling the track window up down (when there are multiple tracks), and scrolling numbers up and down (in time controls), and scrolling choices up and down (in multi-choice controls), and probably other things up and down.
audentis
Post by audentis » Tue Mar 12, 2019 11:58 am
First of all, thanks your response.
I am aware of shift-key modifier, but in my use that remains cumbersome. I rarely ever have projects where I need vertical scrolling, because usually I'm working with no more than 5 mono tracks. That makes the default scroll wheel functionality literally useless to me.
The reason I italicized in your quote is a purely technical one. From my own programming experience I understand this will make implementing my request more time consuming, but then again from a user perspective this feels arbitrary. In more general terms, from a user perspective it's strange (and mildly annoying) that none of the mouse button configurations are rebindable, but horizontal scrolling is the one that most stands out to me.
I fully understand you have to make a trade off in how you invest your resources (including time), but having the option to scroll sideways without shift would be incredibly appreciated by me.
In closing, thank you for your consideration. I'll rest my case, unless you happen to appreciate the discussion or have any further questions about my perspective.
Post by steve » Tue Mar 12, 2019 12:06 pm
OK, I just wanted to ensure that you were aware of the modifier key options.
I've logged your interest in configurable mouse bindings on the "Feature request" page of the Audacity wiki.
ginobean
Post by ginobean » Sun Mar 31, 2019 2:13 pm
It seems like it would be a fairly simple matter to have Audacity pick up the mouse settings from the audacity.cfg file, as it's already picking up the keyboard redefinitions from that file.
Re: "For example, mouse wheel scroll is bound to scrolling the track window up down (when there are multiple tracks), and scrolling numbers up and down (in time controls), and scrolling choices up and down (in multi-choice controls), and probably other things up and down."
It should be a fairly simple matter to decouple these mouse behaviors, by adding these abstractions (as an example):
ScrollTrackWindowUp=<shift mousewheel-up>
ScrollTrackWindowDown=<shift mousewheel-down>
ScrollTimeControlNumbersUp=<shift mousewheel-up>
ScrollTimControlNumbersDown=<shift mousewheel-down>
ScrollChoicesUp=<shift mousewheel-up>
ScrollChoicesDown=<shift mousewheel-down>
ScrollTimelineLeft=<mousewheel-up>
ScrollTimelineRight=<mousewheel-down>
Post by steve » Sun Mar 31, 2019 3:06 pm
Audacity is open source software. Is this a feature that you can develop yourself?
Edgar
Forum Crew
Post by Edgar » Mon Apr 01, 2019 12:02 am
I have a client for whom I make this change with every major Audacity release. Ignoring the code which displays it as a non-standard Audacity, there's only a couple of lines of code to change. My client doesn't want a preference but that would only add a couple of more lines of code.
+1 for making mousing and gesturing completely user-configurable.
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
konst007
Operating System: Windows 7
Post by konst007 » Tue May 11, 2021 9:02 pm
Hello!
Anything new on this topic?
I would also love to configure horizontal scroll without a modifier key, just by mouse wheel, even sacrificing the vertical scroll.
And I cannot program it myself, unfortunately. Does it really need to be that restrictive?
Thank you very much in advance.
waxcylinder
Post by waxcylinder » Wed May 12, 2021 10:00 am
One workaround for this is to use a Mac with a Magic Mouse
There you can get horizontal scrolling with a L/R gesture on the Magic Mouse
konst007
Post by konst007 » Wed May 12, 2021 10:41 am
Thank you for the workaround proposal, unfortunately I don't have a Mac.
Apart of that, I am much and frequently switching between Kdenlive (scrolling by wheel) and Audacity (Ctrl-wheel), and it takes an unjustified amount of attention. Still - does it need to be that restrictive? Just why?
Again, I'm absolutely delighted by Audacity and the effort put by the team in its development.
