Apparently, Effect > Equalization hangs onto the last known good curve until it’s changed.
Effect > Noise Reduction > Profile might do that. I’ve had multiple similar clips to noise reduce but only some of them had convenient Room Tone.
Wouldn’t it be better if the effect could work out the noise floor from a single application of the effect rather than two applications?
My version does . The only caveat is that you have to make sure that all of the controls are adjusted appropriately before taking the noise sample. “Undo” is your friend.
Yes, but in my example, I would get wildly different results from clips taken from one performance. In one clip missing room tone, it might try to use my voice as Profile because that’s the quietest thing in the clip.
This is the same thing that occasionally kills ACX Check. “Why do I suddenly have -20dB noise floor instead of the expected -65dB?”
Because in this clip, you never shut up long enough to find Room Tone.
You could use a completely different Profile technique, such as how cellphones work. Any sound present for the whole clip is probably noise.
Can you do both?
Reduce? [OK (from selected Profile) | AUTO (you figure it out)]
I can see Koz’ point here - but I would prefer it to be able to store several noise profiles for recall and use e.g.
Peter.
To apply same noise reduction profile to mutiple tracks, i do the below
optional A) Select Effect/Noise Reduction
B) Adjust levels in step 2 and preview
This will apply the noise sample to all selected tracks.
Works great for concerts where tracks have already been split from the same source.
- Room noise floor
- BBC FM carrier hiss
- Website carrier hiss
The Current Noise Profile is Saint Babadook Sackbut Recital.
One of the presets is “Auto.”
Not as default, no. All Audiobook chapters need to match.
