Is there updated build instructions for compiling Audacity?
Building and customizing Audacity from the source code.
Re: Is there updated build instructions for compiling Audaci
Permanent link to this post Posted by richabhawsar » Fri Apr 29, 2016 9:39 am
I got success for sudo <path to Audacity source>/mac/build_wxwidgets .
result is as below :
The installation of wxWidgets is finished. On certain
platforms (e.g. Linux) you'll now have to run ldconfig
if you installed a shared library and also modify the
LD_LIBRARY_PATH (or equivalent) environment variable.
wxWidgets comes with no guarantees and doesn't claim
to be suitable for any purpose.
Read the wxWindows Licence on licencing conditions.
~/src/wxWidgets-3.0.2
richa76s-iMac:wxWidgets-3.0.2
So, now I tried running Audacity xcodeproj via both Xcode IDE and xcodebuild command , and error is as follows :
ld: library not found for -lcrt1.10.6.o
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Any suggestions ? :cry:
richabhawsar
Operating System: OS X 10.10 Yosemite
Permanent link to this post Posted by Gale Andrews » Fri Apr 29, 2016 11:08 am
Have you tried
Code: Select all
xcode-select --install
Previous
Return to Compiling Audacity
Who is online
Users browsing this forum: Exabot [Bot] and 1 guest
