FYI. Mac build/install still broken 18th Feb
Building and customizing Audacity from the source code.
Permanent link to this post Posted by rachalmers » Thu Feb 18, 2016 9:16 am
Code: Select all
1008 translated messages, 611 fuzzy translations, 1165 untranslated messages.
** INSTALL FAILED **
The following build commands failed:
   ProcessPCH++ /var/folders/3h/hqtl82m17bvcf589cw140vgr0000gn/C/com.apple.DeveloperTools/7.2.1-7C1002/Xcode/SharedPrecompiledHeaders/AudacityHeaders-gpkhleyfhlgepxblgkfbrsuhvpru/AudacityHeaders.h.pch ../src/AudacityHeaders.h normal i386 c++ com.apple.compilers.llvm.clang.1_0.compiler
   ProcessPCH++ /var/folders/3h/hqtl82m17bvcf589cw140vgr0000gn/C/com.apple.DeveloperTools/7.2.1-7C1002/Xcode/SharedPrecompiledHeaders/AudacityHeaders-gwiakxpddldtewbsyhuoiecynzxa/AudacityHeaders.h.pch ../src/AudacityHeaders.h normal i386 objective-c++ com.apple.compilers.llvm.clang.1_0.compiler
(2 failures)
How to fix OSX is talked about here...
probably specifically here...
I'll have a look myself when I get a moment, possibly on the weekend.
Possibly still applies.
Reason: Fixed broken link
rachalmers
Re: FYI. Mac build/install still broken 18th Feb
Permanent link to this post Posted by kozikowski » Fri Feb 19, 2016 8:35 pm
Any word?
xcodebuild clean -configuration Release Failing on Mac
Permanent link to this post Posted by rachalmers » Sat Feb 20, 2016 10:08 am
Code: Select all
    /bin/sh /Users/robert/src/Audacity/mac/scripts/create_info_header.sh
src/Audacity.h:164:10: fatal error: 'memory' file not found
#include <memory>
1 error generated.
Command /bin/sh emitted errors but did not return a nonzero exit code to indicate failure
rachalmers
Permanent link to this post Posted by Gale Andrews » Sat Feb 20, 2016 12:32 pm
I merged the topics. Do let us know if you have a solution to propose. Otherwise it will have to wait until Leland can look at it. As I said, we are very short of Mac developers.
Return to Compiling Audacity
Who is online
Users browsing this forum: No registered users and 4 guests
