Mac git not compiling this morning. FYI
Building and customizing Audacity from the source code.
Permanent link to this post Posted by rachalmers » Mon Feb 15, 2016 9:46 am
Mac build install failed this morning .. release.log is attached...
This morning being Monday 15th Feb. GMT
I saw on the mail list that something had been done that may have broken the mac src. Could this be the result?
xcodebuild clean -configuration Release
xcodebuild -configuration Release install 2>&1 | tee release.log
** INSTALL FAILED **
The following build commands failed:
ProcessPCH++ /var/folders/3h/hqtl82m17bvcf589cw140vgr0000gn/C/com.apple.DeveloperTools/7.2.1-7C1002/Xcode/SharedPrecompiledHeaders/AudacityHeaders-gpkhleyfhlgepxblgkfbrsuhvpru/AudacityHeaders.h.pch ../src/AudacityHeaders.h normal i386 c++ com.apple.compilers.llvm.clang.1_0.compiler
ProcessPCH++ /var/folders/3h/hqtl82m17bvcf589cw140vgr0000gn/C/com.apple.DeveloperTools/7.2.1-7C1002/Xcode/SharedPrecompiledHeaders/AudacityHeaders-gwiakxpddldtewbsyhuoiecynzxa/AudacityHeaders.h.pch ../src/AudacityHeaders.h normal i386 objective-c++ com.apple.compilers.llvm.clang.1_0.compiler
(2 failures)
Robert Chalmers
Mac mini 6.2 - 2012, Intel Core i7,2.3 GHz, Memory:16 GB. El-Capitan 10.11. 2TB Storage made up of -
Drive 0:HGST HTS721010A9E630. Upper bay. Drive 1:ST1000LM024 HN-M101MBB. Lower Bay
release.log.zip
(69.25 KiB) Downloaded 33 times
rachalmers
Re: Mac git not compiling this morning. FYI
Permanent link to this post Posted by Gale Andrews » Mon Feb 15, 2016 1:14 pm
Thanks. I attached the log to the thread you started on -devel.
Most likely, http://audacity.238276.n2.nabble.com/Did-I-break-the-Mac-build-td7572487.html is the cause.
You could try https://github.com/Paul-Licameli/audacity/tree/mac-fix . I will try that one.
Permanent link to this post Posted by rachalmers » Mon Feb 15, 2016 2:54 pm
Gale Andrews wrote:Thanks. I attached the log to the thread you started on -devel.
Just tried it.
Same problem as last time
Code: Select all
   ProcessPCH++ /var/folders/3h/hqtl82m17bvcf589cw140vgr0000gn/C/com.apple.DeveloperTools/7.2.1-7C1002/Xcode/SharedPrecompiledHeaders/AudacityHeaders-fyrxcitbdoqegfashzjmcwpvbvct/AudacityHeaders.h.pch ../src/AudacityHeaders.h normal i386 c++ com.apple.compilers.llvm.clang.1_0.compiler
   ProcessPCH++ /var/folders/3h/hqtl82m17bvcf589cw140vgr0000gn/C/com.apple.DeveloperTools/7.2.1-7C1002/Xcode/SharedPrecompiledHeaders/AudacityHeaders-exmldlyzusvtpbanolbukbfivgpl/AudacityHeaders.h.pch ../src/AudacityHeaders.h normal i386 objective-c++ com.apple.compilers.llvm.clang.1_0.compiler
(2 failures)
rachalmers
Permanent link to this post Posted by steve » Mon Feb 15, 2016 5:04 pm
Yes it's broken on Mac at the moment.
I'm not sufficiently experienced developing on OS X to fix it, so we're in the same boat ;)
You can follow the progress on the developers mailing list - the public archive (rapidly updated) is here: http://audacity.238276.n2.nabble.com/au ... 38278.html
or sign up to the list here: https://lists.sourceforge.net/lists/lis ... city-devel
Permanent link to this post Posted by rachalmers » Mon Feb 15, 2016 5:13 pm
steve wrote:Yes it's broken on Mac at the moment.
Thanks - yes, on that.
cheers
rachalmers
Return to Compiling Audacity
Who is online
