Can I install new build alongside existing Audacity?
Building and customizing Audacity from the source code.
Permanent link to this post Posted by rachalmers » Fri Feb 12, 2016 7:42 am
Probably a stupid question, but I have an existing Audacity running on my Mac - and I'm using it in production.
I have just built both Release and Debug versions, apparently successfully. But ... can I install either of the two while the existing production version is on this system? Or are they mutually exclusive? One day I'll buy a development machine...
thanks
Robert
rachalmers
Re: Can I install new build alongside existing Audacity?
Permanent link to this post Posted by Gale Andrews » Fri Feb 12, 2016 1:01 pm
rachalmers wrote:Probably a stupid question, but I have an existing Audacity running on my Mac - and I'm using it in production.
In the context of running
Code: Select all
xcodebuild -configuration Release install
which I assume you mean, you have "installed" it to /tmp/Audacity.dst/.
You can move it to /Applications if you wish providing its folder has a different name to that containing your production version.
You can't run both or all three at the same time, unless you create a "Portable Settings" folder in at least two of the folders containing Audacity.
Return to Compiling Audacity
Who is online
