how to create static build with audacity 1.2.6?
Building and customizing Audacity from the source code.
Permanent link to this post Posted by NEXT » Sat Oct 24, 2015 7:52 pm
Hi,
I'm trying to create a static build of Audacity 1.2.6 so that I can run it on a recent version of Ubuntu. I've been able to successfully build Audacity 1.2.6 by compiling it on Ubuntu Dapper 6.06 running inside of a virtual machine. However, I've checked the output of ./configure --help, and I can't find any options referring to static compilation. I think that in recent Audacity versions, one can use ./configure --enable-static to perform a static build, but I'm not sure whether this would also work on Audacity 1.2.6.
I'd appreciate any guidance anyone can offer as to how I can accomplish this. Thanks,
NEXT
Re: how to create static build with audacity 1.2.6?
Permanent link to this post Posted by Gale Andrews » Sat Oct 24, 2015 8:07 pm
There is no technical support for Audacity 1.2.6 any longer. It is long obsolete. ;)
For what purpose do you want to run 1.2.6? There may be a better solution than trying to force a native Linux Audacity 1.2.6 to run on modern Ubuntu. Why not just run 1.2.6 in the Dapper virtual machine?
If you must do it, a quicker solution may be to install Wine and then install the Windows version of Audacity 1.2.6 from http://www.oldfoss.com/Audacity.html.
Return to Compiling Audacity
Who is online
Users browsing this forum: No registered users and 3 guests
