Trouble building 2.1.1 on Ubuntu Vivid [SOLVED]
Building and customizing Audacity from the source code.
Permanent link to this post Posted by ka1ssr » Sat Jul 25, 2015 1:56 am
I'm having trouble building 2.1.1 on Ubuntu 15.04 (Vivd). I downloaded and un-archived the source tarfile with no errors. Then I executed 'sudo apt-get build-dep audacity' to get the dependencies. Configure seemed to run okey, but the text scrolled by so fast I don't know if there were any serious errors. Finally ran make, which aborted after a while with the following...
Code: Select all
Makefile:2620: recipe for target 'audacity-AudacityApp.o' failed
make[2]: *** [audacity-AudacityApp.o] Error 1
make[2]: Leaving directory '/home/ka1ssr/Downloads/audacity-minsrc-2.1.1/src'
Makefile:1333: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/ka1ssr/Downloads/audacity-minsrc-2.1.1/src'
Makefile:716: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
I am attaching the config.log file in case someone spots something I missed.
Many thanks for your help.
Bill
config.log
Configure log file
(86.45 KiB) Downloaded 57 times
ka1ssr
Re: Trouble building 2.1.1 on Ubuntu Vivid
Permanent link to this post Posted by steve » Sat Jul 25, 2015 11:08 am
Looks like you are building with WxGTK-3.0, which is not yet supported.
Probably the easiest solution would be to install Audacity 2.1.1 from this PPA: https://launchpad.net/~ubuntuhandbook1/ ... u/audacity
Re: Trouble building 2.1.1 on Ubuntu Vivid [SOLVED]
Permanent link to this post Posted by ka1ssr » Mon Jul 27, 2015 12:36 am
You are awesome! Added the PPA and upgraded. Everything works!
Many thanks for your prompt reply and help.
Bill
ka1ssr
Return to Compiling Audacity
Who is online
Users browsing this forum: No registered users and 3 guests
