I found an apparent bug in valnum.cpp
Building and customizing Audacity from the source code.
RandomTroll
Operating System: GNU/Linux other
Post by RandomTroll » Thu Dec 25, 2014 5:52 am
This bit of code from valnum.cpp declares c inside a conditional but uses it outside the conditional. Moving its declaration outside the conditional allowed compiling.
Code: Select all
void wxNumValidatorBase::OnChar(wxKeyEvent& event)
    // By default we just validate this key so don't prevent the normal
    // handling from taking place.
    event.Skip();
    if ( !m_validatorWindow )
        return;
#if wxUSE_UNICODE
    const int ch = event.GetUnicodeKey();
    const int c = event.GetKeyCode();
    if ( c > WXK_START )
        // It's a character without any Unicode equivalent at all, e.g. cursor
        // arrow or function key, we never filter those.
        return;
#else // !wxUSE_UNICODE
    const int ch = event.GetKeyCode();
    if ( ch > WXK_DELETE )
        // Not a character neither.
        return;
#endif // wxUSE_UNICODE/!wxUSE_UNICODE
    if ( c < WXK_SPACE || c == WXK_DELETE )
        // Allow ASCII control characters and Delete.
        return;
Contact:
Re: I found an apparent bug in valnum.cpp
Post by steve » Thu Dec 25, 2014 1:18 pm
Thanks for the report.
I'll pass this on to the developers.
I agree that this is an error, but I'm surprised that it caused a problem because (normally) we should be using Unicode.
RandomTroll
Post by RandomTroll » Thu Dec 25, 2014 5:26 pm
I figured that, being the first person to report this bug so late in the day, and it only happens to people not compiling for unicode, I must be the first to try. I don't disable unicode with configure; it's enabled by default, so I don't know why this happened to me.
Contact:
Post by steve » Sun Dec 28, 2014 8:10 pm
A fix for the "valnum" bug has just been committed into the current "alpha" code.
If you're interested, this is what was committed:
Code: Select all
Modified:
  /audacity-src/trunk/src/widgets/valnum.cpp
--- /audacity-src/trunk/src/widgets/valnum.cpp        Sun Nov 16 13:39:18 2014 UTC
+++ /audacity-src/trunk/src/widgets/valnum.cpp        Sun Dec 28 20:02:00 2014 UTC
@@ -159,6 +159,7 @@
+    const int c = ch;
