Can't get scripting to work on Lubuntu 13.10
Building and customizing Audacity from the source code.
Permanent link to this post Posted by d.t. » Tue May 20, 2014 4:25 am
I am using Lubuntu 13.10.
I have downloaded and compiled Audacity 2.0.6 as of today.
I have successfully compiled Audacity and it runs fine.
I also followed the directions for compiling mod-script-pipe, it compiles fine and copies the mod-script-pipe.so file to the modules directory.
Both Audacity and mod-script-pipe.so were built today within minutes of one another.
But when I launch Audacity it doesn't seem to pick up the scripting module. This is what I get when I try running the test script
Code: Select all
   ~/audacity-read-only/scripts$ ./pipe-test.pl
   Could not open /tmp/audacity_script_pipe.to.1000 at ./pipe-test.pl line 46.
I check the modules directory and see the .so file is there
Code: Select all
   [email protected]:~/audacity-read-only/modules$ ls -al
   total 36
   drwxr-xr-x  2 browser browser  4096 May 19 09:01 .
   drwxr-xr-x 20 browser browser  4096 May 19 19:50 ..
   -rwxr-xr-x  1 browser browser 25101 May 19 20:01 mod-script-pipe.so
I look in the /tmp/ directory and neither pipe is there even though Audactiy is running.
What's a good way to debug this?
Thanks!
--DT
d.t.
Re: Can't get scripting to work on Lubuntu 13.10
Permanent link to this post Posted by steve » Tue May 20, 2014 8:41 am
I presume that you read the bit where it says that Mod Script Pipe is experimental and not supported ;)
Try creating a folder:
Code: Select all
~/.audacity-files/modules/
Put the mod-script-pipe.so file into that folder, then restart Audacity.
Any better?
There is a test perl script included in the SVN tree: "/scripts/pipe-test.pl"
Permanent link to this post Posted by d.t. » Tue May 20, 2014 3:56 pm
Funny -- the make puts the mod-script-pipe.so file in ~/audacity-read-only/modules -- I didn't see any reference to ~/.audacity-files.
The documentation says, and I quote:
"Under GCC, move into the lib-src/mod-script-pipe directory and type "make". This will build the module and copy the ".so" to the modules directory."
The implication is that everything is ready to roll.
Thank you for the pointer about ~/.audacity-files. I copied mod-script-pipe.so to that directory and now when Audacity starts up it sees the module.
I'll change my local version so make puts the file in the right place.
Time to go try it out!
--DT
d.t.
Permanent link to this post Posted by steve » Tue May 20, 2014 4:27 pm
What should happen, if this were part of the Audacity release, is that building would create the module .SO, then installing would copy it to a modules folder in the installation directory. Mod-script-pipe is not part of the official release, so it does not get "installed".
By default, building from source and installing would put plug-ins into:
/usr/local/share/audacity/plugins/
and modules into:
/usr/local/share/audacity/modules/
By default these folders are owned by root, which is not very convenient for installing optional plug-ins or modules, but fortunately you can also use:
~/.audacity-files/plugins/
and
Permanent link to this post Posted by Gale Andrews » Fri May 23, 2014 8:58 pm
d.t. wrote:The documentation says, and I quote:
I have clarified the Manual for the next release.
Permanent link to this post Posted by ariakan » Thu Dec 17, 2015 4:51 pm
Hi
im facing the same problem (with ubuntu 15.10)
I downloaded audacity from git
configure the project
then I compiled audacity
no error
i execute audacity
then i runned the test script in ./script
but it return me
<code>
Could not open /tmp/audacity_script_pipe.to.1000 at pipe-test.pl line 46
</code>
any one can help me?
ariakan
Return to Compiling Audacity
Who is online
Users browsing this forum: No registered users and 2 guests
