libsoxr library in Windows x64 platform
Building and customizing Audacity from the source code.
volkanozyilmaz
Post by volkanozyilmaz » Fri Dec 28, 2012 10:37 am
Hello,
I am trying to compile libsoxr library for Windows x64 platform.
In Windows x64 platform inline asm is not supported and these lines of code can't be compile;
static __inline int fetestexcept(int excepts)
short status_word;
__asm fnstsw status_word
return status_word & excepts & FE_ALL_EXCEPT;
static __inline int feclearexcept(int excepts)
int16_t status[14];
__asm fnstenv status
status[2] &= ~(excepts & FE_ALL_EXCEPT);
__asm fldenv status
return 0;
In 64bit OS X platform it is compiling because there is fenv.h file.
Is there a solution for this?
Best,
Re: libsoxr library in Windows x64 platform
Post by Gale Andrews » Sat Dec 29, 2012 2:09 am
volkanozyilmaz wrote:I am trying to compile libsoxr library for Windows x64 platform.
There is no need to build libsoxr separately. Just check out latest Audacity HEAD from SVN, open winaudacity.sln then press Build > Build Solution in VS 2008. See here: http://wiki.audacityteam.org/wiki/Developing_On_Windows .
volkanozyilmaz wrote: In Windows x64 platform inline asm is not supported and these lines of code can't be compile;
short status_word;
int16_t status[14];
__asm fldenv status
return 0;
Libsoxr is a third-party library so not directly related to Audacity.
Have you tried cmake http://www.cmake.org/cmake/resources/software.html ?
In spite of what you say, http://dl.dropbox.com/u/8835547/soxr-0. ... ce.tar.bz2 compiles in Release build for me on Windows 7 x64 VS 2008 using the vcproj file.
Or you can try latest git http://sourceforge.net/p/soxr/code/ci/c ... 1e0a/tree/ .
If you have some reason to build a standalone libsoxr and you have an issue you will need to contact the developer of the library (Rob Sykes) http://audacity.238276.n2.nabble.com/us ... ser=392503 .
volkanozyilmaz
Post by volkanozyilmaz » Sat Dec 29, 2012 8:11 am
Hello Gale,
Thank you for your answer.
Your are right about that it is not directly related to Audacity. I will contact with Rob.
But I can't understand one think. x64 platform doesn't support inline asm. How you can compile this with inline asm in microsoft compiler / x64 platform.
I am using VC++ express 2012. I have looked the last version of libsoxr and these inline asm code still there.
Best,
volkanozyilmaz
Post by volkanozyilmaz » Sat Dec 29, 2012 12:32 pm
Hello Again,
I could compile with MinGW64 gcc compilers. I just wanted to write here maybe because somebody else can need it.
Best,
Post by Gale Andrews » Sat Dec 29, 2012 11:00 pm
volkanozyilmaz wrote:But I can't understand one think. x64 platform doesn't support inline asm. How you can compile this with inline asm in microsoft compiler / x64 platform.
I thought perhaps VS 2008 still supported inline ASM on x64, but according to this, not:
http://msdn.microsoft.com/en-us/library ... 90%29.aspx .
Or maybe it was because I moved the obj files into the src directory? There were other errors if I didn't do that. Or is it using MASM and I don't know that? Anyway, if Rob sheds some light on it, feel free to post.
Thanks
volkanozyilmaz
Post by volkanozyilmaz » Sun Dec 30, 2012 11:24 am
Thanks
I don't know about vc2008's behavior, maybe it can compile (actually I don't think so). It is not about moving the obj files because it is about creating obj file. When you compile a file it will be an obj file first and I couldn't compile the file because of inline asm commands.
Now, with gcc I don't have any problem.
Thanks,
