I was following these instructions: http://audacityteam.org/wiki/index.php? ... g_On_Linux
After installing WxWidgets and some other stuff that it said was reuired, "./configure" completed without any errors, but "make" fails with the following errors:
Code: Select all
make[5]: Entering directory `/home/steve/audacity/lib-src/redland/raptor/src'
yacc -b parsedate -p raptor_parsedate_ -d -v ./parsedate.y
yacc: e - line 167 of "./parsedate.y", syntax error
%pure_parser
make[5]: *** [parsedate.c] Error 1
make[5]: Leaving directory `/home/steve/audacity/lib-src/redland/raptor/src'
make[4]: *** [all] Error 2
make[4]: Leaving directory `/home/steve/audacity/lib-src/redland/raptor/src'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/steve/audacity/lib-src/redland/raptor'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/steve/audacity/lib-src/redland'
make[1]: *** [redland-recursive] Error 2
make[1]: Leaving directory `/home/steve/audacity/lib-src'
make: *** [audacity] Error 2
[EDIT]
I've had another couple of goes on another machine - this machine will definitely build Audacity 1.3.5 perfectly, but no go with Audacity 1.3.6
I can post the output from the terminal if that helps.
Is it me or does the 1.3.6 code just not work?
