Problem installing on SUSE 10.3
Building and customizing Audacity from the source code.
ddebevec
Post by ddebevec » Wed Feb 06, 2008 7:36 pm
I was trying to compile the latest beta version of Audacity on my SUSE 10.3 machine, when the following messages occurred:
config.status:647: creating Makefile
config.status:782: WARNING: Makefile.in seems to ignore the --datarootdir setting
config.status:647: creating src/Makefile
config.status:647: creating lib-src/Makefile
config.status:647: creating lib-src/allegro/Makefile
config.status:647: creating lib-src/expat/Makefile
config.status:647: creating lib-src/libnyquist/Makefile
config.status:647: creating lib-src/libvamp/Makefile
config.status:647: creating lib-src/portaudio/pa_unix_oss/Makefile
config.status:647: creating locale/Makefile
config.status:782: WARNING: locale/Makefile.in seems to ignore the --datarootdir setting
config.status:647: creating tests/Makefile
config.status:647: creating src/configunix.h
configure:9062: === configuring in lib-src/FileDialog (/tmp/audacity-src-1.3.4-beta/lib-src/FileDialog)
configure:9165: running /bin/sh ./configure '--prefix=/usr/local' '--with-wx-config=/usr/bin/wx-config' '--with-pa-include=../portaudio-v19/include' --cache-file=/dev/null --srcdir=.
configure:9170: error: ./configure failed for lib-src/FileDialog
I’m not sure what to do at this point. Can someone give me an idea of what may be causing this problem?
Thanks,
David
Re: Problem installing on SUSE 10.3
Post by steve » Mon Feb 11, 2008 11:02 pm
I found a few references to problems with Open SUSE which lead me to this page:
http://en.opensuse.org/Audacity
Hope that helps.
ddebevec
Post by ddebevec » Thu Feb 14, 2008 9:54 pm
That worked. I was originally trying to compile the app based on the instructions on the download pages. This works so much easier .
