Hi,
I am trying to cross compile Audacity 1.2.6 for arm based development machin.I downloaded Audacity 1.2.6
and wxX11-2.4.2 from sourceforge.net site.I used steps as,
- wxX11-2.4.2
$./configure --disable-unicode
it makes wx-config.
$ make (it fails saying src/gtk/files.lst not found)
files.lst is at src/ so I copied it.
$ cp src/files.lst src/gtl/files.lst
$ make
now it makes some more wxG… at /libs
I copied wx-config to audacity1.2.6 directory - Audacity 1.2.6
$ ./configure --host=arm --disable-debugging --without-libmad --without-id3tag
successful.
updated src/Makefile for CC and CXX as
setenv CC arm_v6_le_uclibc-gcc
setenv CXX arm_v6_le_uclibc-gcc
$ make
fails saying couldn’t find wx/utils.h,wx/ffile.h etc. for compiling src/Blockfile.cpp
Where am I wrong ? Whats missing.
Please share your thoughts.
Regards,
Ajay
