Is anyone else seeing this while building on Windows? I have no problems building other (cmake, C++) projects, but cmake on Audacity gives up the ghost immediately:
M:\gh\aud-build-master>cmake -G "Visual Studio 16 2019" -A x64 -Daudacity_has_asio_support=On -B ..\aud-build -S .
-- Selecting Windows SDK version 10.0.19041.0 to target Windows 10.0.19043.
-- The C compiler identification is MSVC 19.29.30138.0
-- The CXX compiler identification is MSVC 19.29.30138.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - failed
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe - broken
CMake Error at C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/share/cmake-3.20/Modules/CMakeTestCCompiler.cmake:66 (message):
The C compiler
"C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.29.30133/bin/Hostx64/x64/cl.exe"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: M:/gh/aud-build/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/MSBuild/Current/Bin/MSBuild.exe cmTC_50024.vcxproj /p:Configuration=Debug /p:Platform=x64 /p:VisualStudioVersion=16.0 /v:m && Microsoft (R) Build Engine version 16.11.2+f32259642 for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
Microsoft (R) C/C++ Optimizing Compiler Version 19.29.30138 for x64
testCCompiler.c
cl /c /Zi /W1 /WX- /diagnostics:column /Od /Ob0 /D WIN32 /D _WINDOWS /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Zc:inline /Fo"cmTC_50024.dir\Debug\\" /Fd"cmTC_50024.dir\Debug\vc142.pdb" /external:W1 /Gd /TC /errorReport:queue "M:\gh\aud-build\CMakeFiles\CMakeTmp\testCCompiler.c"
M:\gh\aud-build\CMakeFiles\CMakeTmp\testCCompiler.c : fatal error C1090: PDB API call failed, error code '3': M:\gh\aud-build\CMakeFiles\CMakeTmp\cmTC_50024.dir\Debug\vc142.pdb [M:\gh\aud-build\CMakeFiles\CMakeTmp\cmTC_50024.vcxproj]
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:140 (project)
-- Configuring incomplete, errors occurred!
See also "M:/gh/aud-build/CMakeFiles/CMakeOutput.log".
See also "M:/gh/aud-build/CMakeFiles/CMakeError.log".
