Building Audacity 2.4.2 on Debian 10 (with cmake 3.18)
Building and customizing Audacity from the source code.
Post by steve » Sun Aug 16, 2020 5:04 pm
Audacity 2.4.2 requires cmake version 3.15 or later.
At time of writing, the Debian 10 repository version of cmake is 3.13.4-1, which is too old, so the first task is to install a more recent version of cmake.
  1. Uninstall any version of cmake currently installed:
    Code: Select all
    sudo apt purge cmake
  2. Download cmake-3.18.1-Linux-x86_64.sh from https://cmake.org/download/
  3. Copy cmake-3.18.1-Linux-x86_64.sh to /usr/local
    Code: Select all
    sudo cp cmake-3.18.1-Linux-x86_64.sh /usr/local
  4. Navigate to /usr/local and set the executable permission for cmake-3.18.1-Linux-x86_64.sh
    Code: Select all
    cd /usr/local
    sudo chmod +x cmake-3.18.1-Linux-x86_64.sh
  5. Run the installation script:
    Code: Select all
    sudo sh cmake-3.18.1-Linux-x86_64.sh
  6. Follow the on-screen instructions. Note that:
    1. You must respond "Y" when asked if you accept the license agreement
    2. Respond "n" when prompted:
      Code: Select all
      By default the CMake will be installed in:
        "/usr/local/cmake-3.18.1-Linux-x86_64"
      Do you want to include the subdirectory cmake-3.18.1-Linux-x86_64?
      Saying no will install in: "/usr/local" [Yn]:
  7. Check the cmake version
    Code: Select all
    cmake --version
Once cmake 3.18 is installed, follow the Ubuntu 20.04 instructions to install Audacity: viewtopic.php?p=398471#p398471
