build 2.4.2 into PPA
Building and customizing Audacity from the source code.
ubuntuhandbook
Post by ubuntuhandbook » Sat Jun 27, 2020 1:07 pm
Hi, I'm the maintainer of ppa:ubuntuhandbook1/audacity.
Just noticed that Audacity has switched to cmake. And I've read steve's post about building on Ubuntu 20.04.
However, the launchpad builders do not have internet connection while the build process requires cloning wxwidgets from github.
:( I'm not a programmer , has no skill to hack on the cmake file. So I'm here to ask if possible to upload wxwidgets (grab from github/audacity/wxwidgets) along with Audacity source into launchpad. More detailed instructions would be appreciated.
Re: build 2.4.2 into PPA
Post by steve » Sat Jun 27, 2020 9:00 pm
Hi, did you see my reply here: viewtopic.php?p=398885#p398885
Does that help?
ubuntuhandbook
Post by ubuntuhandbook » Sun Jun 28, 2020 2:02 pm
Thanks steve, I've figured out building wxwidgets. However, I'm running into another issue. I've seen similar issue in github bug reporting page, though I don't know exactly where to add --no-undefined flag.
/usr/bin/ld: ./obj-x86_64-linux-gnu/modules/mod-script-pipe/./modules/mod-script-pipe/ScripterCallback.cpp:128: undefined reference to `wxString::Replace(wxString const&, wxString const&, bool)'
/usr/bin/ld: ./obj-x86_64-linux-gnu/modules/mod-script-pipe/./modules/mod-script-pipe/ScripterCallback.cpp:129: undefined reference to `wxEmptyString'
/usr/bin/ld: ./obj-x86_64-linux-gnu/modules/mod-script-pipe/./modules/mod-script-pipe/ScripterCallback.cpp:134: undefined reference to `wxArrayString::Clear()'
/usr/bin/ld: ./obj-x86_64-linux-gnu/modules/mod-script-pipe/./modules/mod-script-pipe/ScripterCallback.cpp:141: undefined reference to `wxString::Mid(unsigned long, unsigned long) const'
/usr/bin/ld: ./obj-x86_64-linux-gnu/modules/mod-script-pipe/./modules/mod-script-pipe/ScripterCallback.cpp:141: undefined reference to `operator+(wxString const&, wchar_t const*)'
/usr/bin/ld: ./obj-x86_64-linux-gnu/modules/mod-script-pipe/./modules/mod-script-pipe/ScripterCallback.cpp:141: undefined reference to `wxArrayString::Add(wxString const&, unsigned long)'
Full build log: https://launchpadlibrarian.net/48619852 ... ING.txt.gz
Post by steve » Sun Jun 28, 2020 2:20 pm
Could you post a link to that/those issues.
ubuntuhandbook
Post by ubuntuhandbook » Sun Jun 28, 2020 3:07 pm
Seems to be:
https://github.com/audacity/audacity/issues/552
Though I'm building for Ubuntu.
Post by steve » Sun Jun 28, 2020 4:01 pm
I think the problem is that mod-script-pipe requires wxWidgets but for some reason it isn't found when building the module.
Are you setting LD_LIBRARY_PATH, and if not, how does cmake know where to find wxWidgets?
